Project Neptune
Neptune is an open source implementation of an open protocol for high-throughput multimedia drone communications from Open Research Institute. This protocol directly competes against the proprietary designs from DJI.
Implementation prototypes use the Xilinx Ultrascale+ and Analog Devices 9002 RFSOC. These development boards are accessible at no cost through ORI Remote Labs West. Amateur radio bands will be used to the fullest extent. Full Vivado and MATLAB licenses are included.
A review of the OFDM-based physical layer draft specification will happen shortly and invitations are going out now. Participants must be proficient with the design review process, understand OFDM, accept our developer and participant code of conduct, and support open source work.
To join as a participant please visit https://openresearch.institute/getting-started
Join the #neptune channel on ORI Slack.
To keep informed about our work you should know about our newsletter at https://www.openresearch.institute/newsletter-subscription/
Thank you to everyone that has made this innovative and groundbreaking project possible. We deeply appreciate your support and we will be successful with this design.
