Science and Technology for EVE 2028
Do you like amateur radio, amateur radio astronomy, and digital communications? Are you excited about the Earth-Venus-Earth communications attempts in 2025 and 2026?
The Earth and Venus are next aligned on the same side of the sun on 1 June 2028. Looking at the link analysis, the geometry of 2028 is a bit different than 2026. Venus passes much closer to the Sun’s disk in June 2028, at a separation of only about 0.8 degrees, compared to 6.5 degrees away in October 2026. In June 2028, Venus will be located high in the northern sky with a positive declination of approximately 22 degrees 54 minutes.
If you would like to help organize an EVE communications attempt (bouncing a signal off of Venus to be received back here on Earth), then please get in touch. We’ll do all we can to support, educate, and publicize. We have a modulation scheme designed specifically for the low coherence time EVE channel. We have an EME test station at ORI so that research and development can happen year-round for EVE work. Welcome aboard!
https://openresearch.institute/getting-started
One Reply to “Science and Technology for EVE 2028”
  1. Would like to participate but depends on the type of radio and antenna. If you could provide the details would appreciate it.
    I don’t have a personal website but am associated with the ARRL in the US.
