August Technical Puzzle Hint
— PART 2: THE INVESTIGATION
— VHDL Testbench to expose the Costas Loop Error Starvation
— This testbench will demonstrate the intermittent lock loss
— and help us discover the root cause through systematic
— investigation.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.MATH_REAL.ALL;
use STD.TEXTIO.ALL;
use IEEE.STD_LOGIC_TEXTIO.ALL;
entity tb_costas_mystery is
end entity;
architecture testbench of tb_costas_mystery is
    constant CLK_PERIOD : time := 10 ns;  — 100 MHz
    constant DATA_WIDTH : integer := 16;
    constant PHASE_WIDTH : integer := 12;
    — Testbench signals
    signal clk : std_logic := ‘0’;
    signal reset : std_logic := ‘1’;
    signal freq_select : std_logic := ‘0’;
    signal rf_input : signed(DATA_WIDTH-1 downto 0);
    — DUT outputs
    signal i_data, q_data : signed(DATA_WIDTH-1 downto 0);
    signal phase_error : signed(DATA_WIDTH-1 downto 0);
    signal vco_freq : signed(PHASE_WIDTH-1 downto 0);
    signal lock_detect : std_logic;
    — Stimulus generation
    signal input_phase : real := 0.0;
    signal carrier_freq : real := 10000.0;  — 10 kHz carrier
    signal noise_level : real := 0.1;       — 10% noise
    — Investigation signals
    signal lock_time_f1 : time := 0 ns;
    signal lock_time_f2 : time := 0 ns;
    signal lock_lost_f2 : boolean := false;
    signal test_phase : integer := 0;
    — Random number generation for noise
    shared variable seed1, seed2 : integer := 1;
    component costas_loop_puzzle is
        generic (
            F1_OFFSET : integer := 1000;
            F2_OFFSET : integer := 3000
        port (
            clk         : in  std_logic;
            reset       : in  std_logic;
            rf_input    : in  signed(DATA_WIDTH-1 downto 0);
            freq_select : in  std_logic;
            i_data      : out signed(DATA_WIDTH-1 downto 0);
            q_data      : out signed(DATA_WIDTH-1 downto 0);
            phase_error : out signed(DATA_WIDTH-1 downto 0);
            vco_freq    : out signed(PHASE_WIDTH-1 downto 0);
            lock_detect : out std_logic
    end component;
begin
    — Clock generation
    clk <= not clk after CLK_PERIOD / 2;
    — Device Under Test
    DUT: costas_loop_puzzle
        generic map (
            DATA_WIDTH => DATA_WIDTH,
            PHASE_WIDTH => PHASE_WIDTH,
            F1_OFFSET => 1000,
            F2_OFFSET => 3000
        port map (
            clk => clk,
            reset => reset,
            rf_input => rf_input,
            freq_select => freq_select,
            i_data => i_data,
            q_data => q_data,
            phase_error => phase_error,
            vco_freq => vco_freq,
            lock_detect => lock_detect
    — RF Input Signal Generation
    process(clk)
        variable rand_val : real;
        variable current_freq : real;
        variable signal_amplitude : real;
        variable noise_component : real;
    begin
        if rising_edge(clk) then
            — Select frequency based on freq_select
            if freq_select = ‘0’ then
                current_freq := carrier_freq + 1000.0;  — F1
            else
                current_freq := carrier_freq + 3000.0;  — F2
            end if;
            — Generate phase
            input_phase <= input_phase + (current_freq * 2.0 * MATH_PI * real(CLK_PERIOD / 1 sec));
            — Add noise (uniform random)
            uniform(seed1, seed2, rand_val);
            noise_component := (rand_val – 0.5) * noise_level * 32767.0;
            — Generate clean signal + noise
            signal_amplitude := 32767.0 * 0.8;  — 80% of full scale
            rf_input <= to_signed(integer(
                signal_amplitude * cos(input_phase) + noise_component
            ), DATA_WIDTH);
        end if;
    end process;
    — Main Test Sequence
    process
        variable l : line;
        variable lock_start_time : time;
    begin
        — Initial setup
        write(l, string'(“=== COSTAS LOOP MYSTERY INVESTIGATION ===”));
        writeline(output, l);
        write(l, string'(“Testing for intermittent lock loss between F1 and F2…”));
        reset <= ‘1’;
        freq_select <= ‘0’;
        wait for 100 ns;
        reset <= ‘0’;
        — TEST 1: Lock to F1 and measure performance
        write(l, string'(“TEST 1: Locking to F1 (1kHz offset)…”));
        test_phase <= 1;
        lock_start_time := now;
        wait until lock_detect = ‘1’ for 50 us;
        if lock_detect = ‘1’ then
            lock_time_f1 <= now – lock_start_time;
            write(l, string'(“✓ F1 Lock achieved in “));
            write(l, now – lock_start_time);
        else
            write(l, string'(“✗ F1 Lock FAILED – timeout”));
        end if;
        — Let it settle and verify stability
        wait for 10 us;
        — TEST 2: Switch to F2 and observe behavior
        write(l, string'(“TEST 2: Switching to F2 (3kHz offset)…”));
        test_phase <= 2;
        freq_select <= ‘1’;  — Switch to F2
        — Wait a bit and check if lock is maintained or reacquired
        wait for 5 us;
        if lock_detect = ‘0’ then
            write(l, string'(“⚠ Lock lost during F2 transition!”));
            lock_lost_f2 <= true;
            — Wait for reacquisition
            wait until lock_detect = ‘1’ for 100 us;
                lock_time_f2 <= now – lock_start_time;
                write(l, string'(“✓ F2 Lock eventually reacquired in “));
            else
                write(l, string'(“✗ F2 Lock FAILED completely – timeout”));
            end if;
        else
            write(l, string'(“✓ F2 Lock maintained/acquired in “));
        end if;
        — TEST 3: Multiple transitions to expose intermittent behavior
        write(l, string'(“TEST 3: Rapid F1/F2 transitions (stress test)…”));
        test_phase <= 3;
        for i in 1 to 5 loop
            — F1
            freq_select <= ‘0’;
            wait for 2 us;
            write(l, string'(“Transition “));
            write(l, i);
            write(l, string'(” F1: Lock=”));
            write(l, std_logic’image(lock_detect));
            — F2
            freq_select <= ‘1’;
            wait for 2 us;
            write(l, i);
            write(l, string'(” F2: Lock=”));
        end loop;
        — TEST 4: Add noise and see what happens
        write(l, string'(“TEST 4: High noise environment test…”));
        test_phase <= 4;
        noise_level <= 0.3;  — Increase to 30%
        freq_select <= ‘0’;   — Start with F1
        wait for 5 us;
        write(l, string'(“F1 with 30% noise: Lock=”));
        wait for 10 us;
        write(l, string'(“F2 with 30% noise: Lock=”));
        — Final analysis
        write(l, string'(“”));
        write(l, string'(“=== INVESTIGATION SUMMARY ===”));
        write(l, string'(“F1 lock time: “));
        write(l, lock_time_f1);
        write(l, string'(“F2 lock time: “));
        write(l, lock_time_f2);
        write(l, string'(“F2 lock lost during transition: “));
        write(l, boolean’image(lock_lost_f2));
        write(l, string'(“CLUE: Notice the dramatically different behavior between F1 and F2”));
        write(l, string'(“CLUE: Check the loop gains when freq_select changes”));
        write(l, string'(“CLUE: Error starvation occurs when correction signals become too weak”));
        wait;
    end process;
    — Continuous monitoring for debugging
    process(clk)
        variable l : line;
        variable prev_lock : std_logic := ‘0’;
    begin
            — Detect lock transitions for detailed analysis
            if lock_detect /= prev_lock then
                    write(l, time’image(now));
                    write(l, string'(” LOCK ACQUIRED – F”));
                        write(l, string'(“1”));
                    else
                        write(l, string'(“2”));
                    end if;
                    write(l, string'(” Phase Error: “));
                    write(l, integer’image(to_integer(phase_error)));
                else
                    write(l, string'(” LOCK LOST – F”));
                    else
                    end if;
                end if;
            end if;
            prev_lock := lock_detect;
        end if;
    end process;
end testbench;
— WHAT TO LOOK FOR IN THE SIMULATION:
— 1. F1 locks quickly and reliably
— 2. F2 takes much longer to lock (if at all)
— 3. Transitions from F1→F2 often cause lock loss
— 4. Under noise, F2 performance degrades dramatically
— 5. Phase error signals in F2 mode are much smaller
— These symptoms point to ERROR STARVATION in F2 mode!
— The next part will show the solution…
